Clearing a few parts
I'm tidying up my garage and moving some parts on. With spares availability drying up here's a chance to grab a few spares before they go on ebay over the next few days. I've also got some 12a engine parts still to list.... plates, front covers, gears, rotors, OMP's, etc
12a front counterweight - used - £15 shipped
series 3 wheel centre caps - used - £10 shipped SOLD
fuel door release switch - used - £10 shipped
series 3 electric mirror switch - used - £10 shipped SOLD
series 2 electric mirror switch - used - £10 shipped
rear hatch release button - used - £10 shipped
headlamp washer and valet switch - used - £10 shipped
heated rear window switch - used - £10 shipped
Fusible link holder and links - used - £15 shipped SOLD
gearbox to exhaust hanger - used - £10 shipped
series 3 digital clock - used - £12 shipped
series 2 ecu - used - £14 shipped
series 3 ecu - used - £14 shipped Sold
rear interior light - used - £10 shipped Sold
series 3 hazard control - used - £12 shipped Sold
dash centre vents - no damage - to repair/replace your damaged vents - used - £15 shipped SOLD
pair of headlight washer jet rubber covers - used - £10 shipped
rear foglight switch - used - £10 shipped Provisionally Sold
pair of rear quarter light window trims - used - great condition with all pins intact - so hard to find in good used condition these days - £15 shipped SOLD
Centre console arm rest hinge - to repair your broken armrest - used - £10 shipped Sold
12a water pump pulley - used - £10 shipped
12a e-shaft - good condition - used - £30 shipped Sold
headlamp washer pump - used - stripped, cleaned and tested, working fine..... if your washers have given up, it'll be this pump that's seized. £14 shipped SOLD
12a coils - used - £12 each shipped ...... 9 available
Turbo 2 clocks..... slight crack to bottom of plastic.... will be covered by clocks surround when fitted - used - £20 shipped
Turbo 2 clocks - used - taken from my S5 turbo 2 donor car - £30 shipped
Series 2 and series 3 brake caliper rebuild seals - new - comprising of:
A pair of front caliper rebuild seals ( 1 x axle set)
1 x rear brake caliper seal set ( rebuilds 1no caliper only)
Note: you need to buy an extra rear caliper set to rebuild all 4 brakes on your car...... these 3 seal kits will do both front brakes and 1 rear brake only.
The front caliper seals are made by Raybestos and the rear by Centric.... I've been using these for years and they are great.
£30 shipped Sold
Genuine Mazda New Old Stock (boxed) air filter element - NOS - great condition - £15 shipped ( 2 available)
All of the above shipping prices relate to the UK only.... I'll send these parts anywhere in the world at the buyers expense.... overseas shipping will be at cost.
Been thanked: 187 times
Re: Clearing a few parts
PM sent.
PM sent th:
a few more...
Series 3 1983-1985 12a front rotor - used - £55 shipped
Front & rear 12a rotors - used - £110 shipped
Apex seals and corner seals - used - £75 shipped Sold
came out of the above pair of rotors - measured with a micrometer
Series 1 front counterweight - used - £15 shipped
Pair of front Torrington bearings - used - £15 shipped Sold
Fuel cap - used - £7.50 shipped
Rear bumpstop - used - £10 shipped SOLD
12a front stack inc front stationary gear - used - £50 shipped includes front stat gear, Torrington bearings, shims, spacer, oil pump, gears and chain, dizzy drive, locking key, front pulley, pulley bolt and belt pulley.
Rear oil pressure regulator 12a - used - £12 shipped
12a engine bolts - full set - used - £25 shipped
12a Oil metering pump - used - £15 shipped SOLD
3no engine dowels - used - £12 shipped
again, shipped prices relate to UK only,....... overseas shipping at cost.
RB6102
Post by RB6102 »
PM sent
Return to “Parts For Sale”
