Hi Guys
I was just checking the DVLA mot history site and I looked at the mot history for my car from its last test.
It was originally noted as a fail for the following reason
"Exhaust carbon monoxide content after 2nd fast idle exceeds manufacturer's specified limits (8.2.1.2 (a))"
I thought our cars were exempt from this part of the MOT or am I mistaken?
It passed the test after a minor adjustment but this is the only blemish on its MOT history .
If it was failed mistakenly can this be corrected with the DVLA?
Thanks
Emissions Failure MOT
- Has thanked: 44 times
- Been thanked: 118 times
Re: Emissions Failure MOT
They are exempt and it’s been tested by a tester who doesn’t realise or understand this. They are subject to a visual check for smoke only
ian65 wrote: ↑Fri Jun 07, 2019 10:20 pm With the new revamped mot test this old document is superceded..... you can download the latest mot testers guide here from my G Drive... the info you need is highlighted on page 4
https://drive.google.com/open?id=1q7U9B ... Mw1h0xIsFl
Thanks Ian,
I thought you would come up with the definitive answer.
I suppose the only issue is can I get it reversed.
Kev
Kev
