Grear looking car mate and relocating the wing mirrors was I great job 'i thought of doin that to my old fd but never got around to it ' what mirrors are they ?
Dan Dillinger wrote:I was running 30mm hub adapters in that photo. Wheels are 15x6.5 +18 up front 15x7 +11 on the back.
I'm doing a hub swap at the moment to 4x114.3 and i'll be running my 7" wheels up front and i've got 15x8 -6 wheels for the back
What's the clearance going to be like with the 8's on the rear?
The Series 3 is ET40 stock, whereas yours is ET20 - If you swap the front suspension you will add track to the front, what are you doing in the rear? If you swap in the diff, once again you will gain track width.
Fronts are going to be fine, rears are gonna be tight! Think I can make it work though
