Window switches
Window switches
My window switch has developed an annoying intermittent fault, in as much as it won't go down! The wiring appears to be all intact, so the question is are the switches rebuildable? Before I go to the trouble of pulling it to bits, lol. Or is it a case of I need a new one?
Has thanked: 473 times
Re: Window switches
Switches are rebuildable.
Re: Window switches
Thanks, Thomas. I'll have a go at it when it's light then
I just collected the car from the workshop where it had some fueling problems attended to. The windows were steamed up, it was dark, and I had to reverse it out of the alleyway... and I couldn't get the bloody window open to see where I was going :evil: Always the way with these cars; fix one thing, another one breaks :roll:
Has thanked: 156 times
Re: Window switches
have a read of this
viewtopic.php?f=22&t=554
Re: Window switches
lol, cheers Dibs. I knew I'd seen something about it before but somehow completely failed to find that thread :oops: Which is odd cos it's at the bottom of the page this one's on :roll: I admit to utter muppetry, if someone wants to delete this thread please feel free
Re: Window switches
don't try and prise the rocker out of the switch body, go in from the bottom and take the base of the switch off..... be careful when you re-assemble it because it should only go together one way round but is easy to force the clips and re-fit the base plate back to front...... apart from that, it's a piece of cake.
Been thanked: 111 times
Re: Window switches
Post by Chud »
I've got some spares if it all goes horribly wrong and you end up with it scattered across a 10m radius which is what normally happens when I try and gain access to something like that.
Re: Window switches
lol. So far I've bottled it by taking the coward's way out of filling it with WD40 and hoping. It seems to be working so far.... :oops:
How much d'you want for a spare, Timmers? Be nice to know I'm under no pressure when I man up enough to finally take it apart
Re: Window switches
The problem is the fluff and crud that accumulates in there. It is like the belly button of the RX& interior.
Re: Window switches
Post by Chud »
Don't worry about money, I seem to remember an air filter turning up on my doorstep for no exchange of monies. 8-) Just PM me your address.
Return to “Electrics”
