grinding noise
grinding noise
hi guys theres a grinding noise from my alternator when I start the fb when warm but theres no grinding when its stone cold! @ first I thought it was the alternator so I changed it for a brand new one but it still has the same grinding noise as before! any advice please cheers mick
- Has thanked: 3 times
- Been thanked: 111 times
Re: grinding noise
Have you checked for play in the water pump?
How tight are you doing the belt?
Re: grinding noise
i had a double pulley & new belts fitted by powergains 5 months ago they also checked the water pump with no play, water temps never rises pass 30% on the gauge! it only makes the grinding noise for a couple of seconds when i start it up from warm/hot @ 1st i thought it was the broken old alternator but its the same with the new one, is there some sort of adjustment that can b done to fix it??? cheersChud wrote:Have you checked for play in the water pump?
- Has thanked: 482 times
- Been thanked: 192 times
Re: grinding noise
Do you still have the hot start assist connected up? Acctuator unit is mounted on LH strut tower and connects via a long cable to the carb. Opens the throttle a little to assist hot starting. Many have stopped working now or been removed completely.
Get someone to start the car from hot and watch the acctuator. A tiny electric motor pulls the cable back for a short burst, that could be the noise you are hearing? If it only happens when hot, that's my best guess.
Theory number 872 /5
Re: grinding noise
hi dave yes I still have that & I thought that was part of the choke! its sounds like a crunching/grinding noise when ur engines on & u try to start it is the best way I can describe it & im sure its the alternator crunching/grinding on the flywheel! cheers
Re: grinding noise
sorry guys I was having a dumb moment lol ive been working too hard haven`t been away on holiday since 2006 ! & yes its the starter motor that I mean.codge wrote:Do you mean the starter motor Mick?
The alternator isn't near the flywheel.
- MelloYello
- Has thanked: 22 times
- Been thanked: 52 times
Re: grinding noise
cheers m8redarrow wrote:Hey Mick I think there is an app for that - http://grindr.com/
