And if you don't want to hand lap your plates, try these guys who come recommended:
http://www.nlrflatlapping.co.uk
Hand lapping cast iron side plates
Re: Hand lapping cast iron side plates
on any rotary engine if rebuilding, is it recommended to skim the side plates?
apexheid
Not really, check the wear depth at the spark plug side/oppositespoddy wrote:on any rotary engine if rebuilding, is it recommended to skim the side plates?
Max is .004 -.006" on N/A for road going and .006" for racing.
For turbo's max .004" due loss of pressure and leaked.
if it is skim by grinder/lapping work. end play must replace and inlet manifold/exhaust header must be drilled out ovally to fit back.
Also important to do when it doing by grinding, plate must be dead square to stationary gear or the E shaft will eat the bearing.. I know cos I've been there.( I was a grinder..)
Too many to talk about it there and that..
if unsure, give to real expert( Don't give to RX8 so-called specialists) to check it out.
Sorry Folk and again.. no photo.
