Window switches
Re: Window switches
Well, I won a window switch on EBay some time ago. Arrived from the US and got around to swapping it out today. I really should have looked at mine first :( UK spec is each switch with it's own plug (right), US spec for 84/85 is two switches into a single plug.(left) FECK. That, plus the US switch housing is smaller so won't fit our console. FECK , ARSE.
And the plugs are different too :roll: So that was a waste of time then :evil:
So, option two was taking my old switch apart and cleaning it out. Which is surprisingly easy and most satisfying once everything is back together. th:
As has been suggested before, take the switch apart from the bottom. Carefully insert a small bladed screwdriver just enough to release the tongs. Keep the assembly horizontal and pull the top and bottom apart SLOWLY. You may want to mark one face as it only completely re assembles one way. It's easy to waste time trying to figure out why it won't fit back together properly!
This is underneath the rocker switch. It has two plastic columns with a spring each inside and a tiny roller which glides on the contacts. Dust is your friend here as it mixes with the grease and will probably prevent the springs launching the rollers into a sub stratospheric orbit. (disclaimer ... actual results may vary).
The columns with springs
Tiny rollers
Columns with rollers mounted
These are the contacts. All covered in dust and crud. Nice!
The contacts lift out to reveal more crud
Cotton buds are useful for cleaning and reaching into cavities.
About to be reunited
It all works too yay Just be careful and it's an easy job. I'm doing the driver's side tonight :)
Re: Window switches
The driver's side switch was much cleaner inside :o so everything spring loaded (the columns and roller wheels on top) was very eager to part company. Just needed to be careful (slowly, slowly) when separating the switch assembly.
Top tip for reassembly. The switch has writing on one side. Take a note of the wiring color on that same side and you'll reassemble everything correctly first time. th:
KYPREO
Has thanked: 14 times
Been thanked: 39 times
Re: Window switches
Post by KYPREO »
D'oh!
Never assume parts from a LHD series 3 are the same as RHD. They got the complete interior update plus plenty of other changes. I've learnt that lesson myself.
When sourcing parts from the US, their series 2 (81-83), in particular the GSL grade, are often more similar to our RHD series 3.
The carbon problem is because the switch is actually handling the entire current load whenever the windows operate. To prevent this happening again, you can wire in relays, so that all the switch is doing is transferring the current necessary to trip the relay. The relay then handles the current from battery to window motor. ;)
Instructions on this modification are here: http://wright-here.net/cars/rx7/mods/power_windows.html
Has thanked: 473 times
Re: Window switches
KiwiDave wrote:Well, I won a window switch on EBay some time ago. Arrived from the US and got around to swapping it out today. I really should have looked at mine first :( UK spec is each switch with it's own plug (right), US spec for 84/85 is two switches into a single plug.(left) FECK. That, plus the US switch housing is smaller so won't fit our console.
Us spec for 84/85 switches are the same as my german spec 84 car switches. They are only built for the last LHD seven fb, Dave
Re: Window switches
Well, it might be listed on EBay.de quite soon then ;)
Has thanked: 505 times
Been thanked: 451 times
Re: Window switches
My driver side window stuck in the fully down position this morning :( Thankfully it wasn't raining and I was only a few miles from home. I know the switches have been noted as becoming intermittent so I found this thread on a search. Many thanks to those who have trodden this path before me and posted above, as reading through this thread made the job soooo much easier. 45 minutes later and both switches out, dismantled, cleaned, back in and tested fine yay
Some pics for the record (4 cotton buds gave up their lives for the success of this mission :D )
Has thanked: 628 times
Been thanked: 218 times
Re: Window switches
Looking good Casey. Reminds me that I still need to do that write-up for window relays haha.
Moderator Edit: link to window relay topic here - viewtopic.php?p=47776
Return to “Electrics”
