My planned trip in KIMI 3 to JDM Combe last Saturday had to be abandoned. Reason? With the car cleaned to within an inch of it's life and fully packed, I started her up and engaged reverse, to be greeted with crunch. Darn, the clutch bite point had sunk to the floor. Suspecting the clutch slave, I had no time to fix it, so I transferred all the gear over to my RX-8 and took that instead!
I've just got around to taking a look and, as usual, a visual inspection of the slave in situ revealed nothing, but the arm travel was about half what it ought to be.
Slave unbolted and rubber boot removed, viola, failed slave seal!
- 20220715_130814.jpg (116.9 KiB) Viewed 10913 times
Knowing how these slaves have a habit of failing, I had previously ordered not one, but two new slaves from RockAuto on previous orders!
So, job for later is to fit and bleed the new slave. I'll bench bleed the slave before fitting too.
Whilst I was removing the slave, I spotted this wire nearby, emerging from the loom that runs behind the beehive. Should it be connected anywhere?
- 20220715_125658.jpg (180.42 KiB) Viewed 10913 times
