Keith's red S3
Re: Keith's red S3
bloody hell, how lucky is that? :shock: Do you know what caused it in the first place so you can stop it happening again?
Re: Keith's red S3
Well Pip did warn me about carbon apex seals absorbing moisture over time, he said I might be ok if had been kept well oiled. Seems it wasn't oiled well enough.
Re: Keith's red S3
Whats the plan then, are you changing all the apex seals?
Re: Keith's red S3
On the plus side Keith, you only need 1 seal :lol:
I guess you can use all the side seals etc & springs again? When you think what might of happened :o
Re: Keith's red S3
DKWW2000 wrote: Mon Sep 09, 2019 4:45 pm On the plus side Keith, you only need 1 seal :lol:
Yes everything looks fine apart from that seal so a set of apex seals and a soft seal kit I guess.
Re: Keith's red S3
ian65 wrote: Mon Sep 09, 2019 2:20 pm Whats the plan then, are you changing all the apex seals?
Yes thats the plan, evrything else looks good :D
Re: Keith's red S3
Yeah, carbon seals will even begin to break up in storage.
What seals you planning to run?
13B 3mm carbon seals are NLA dude.
Re: Keith's red S3
TOOL wrote: Tue Sep 10, 2019 5:56 am Yeah, carbon seals will even begin to break up in storage.
I'm not sure to be honest, what would you suggest as an alternative?
Re: Keith's red S3
You gotta go steel seals.
They’ll be harder on the housings though.
But you can still get early housings unlike the carbon seals.
Re: Keith's red S3
TOOL wrote: Tue Sep 10, 2019 8:19 pm You gotta go steel seals.
do they need to be 1 piece because of the bridge?
