Guess the do-hicky
DelMonte
Guess the do-hicky
Post by DelMonte »
Couldn't quite work out what this is for. A cable from a lever under the carb goes into this, sounds like a rack and gear wheel inside with an electric cable coming out.
Any ideas?
Has thanked: 5 times
Been thanked: 23 times
Re: Guess the do-hicky
Post by DB RX63 »
Automatic choke ?
it's the hot start assist
Isn't that the warm-start throttle-blipping robot 8-) ? Y'know, gives the throttle a little brummm when you start the car after it's been running up to temp then turned off and on again.
At first I thought it was a specially trained little pixie who ran out and tugged the throttle cable, but rather disappointingly it's this little widget, I think
EDIT: or maybe what Ian said, he's better with being accurate than wot I is :lol:
DelMonte
Post by DelMonte »
If it is, I don't think it's working. Thought it maybe something like that or linked to the auto box to stop it stalling /cutting out.
Post by DB RX63 »
Ah, so that's it then, definitely a widget.........!
DelMonte
Post by DelMonte »
Wow some quick responses.
So cold or warm start assist? Any way to check it's working?
Do-hicky type widget thing with pixies inside running on fairy dust.
sorry, the hot start assist, not the cold.... there's a relay for it on the inner wing behind it.... make sure the contacts are good and clean.... again, part of the over complication of the nikki carb.... i just chucked mine away when I turbo'd it and took the Nikki off
DelMonte
Post by DelMonte »
Thanks once again :-)
I still like the idea of a proper name for it. Warm start assist doesn't quite do it (albeit quite descriptive) .
ian65 wrote:sorry, the hot start assist, not the cold.
YESSSS! :lol: I got something right! I got something right! :D This is the proudest day of my young life *sob* :lol:
