Initail prep 14.JPG (252.97 KiB) Viewed 8400 times
POR15 pre-treatment (de-grease and acid etch):
Final acid etch 2.JPG (207.36 KiB) Viewed 8400 times
Final acid etch 3.JPG (235.06 KiB) Viewed 8400 times
Final acid etch 6.JPG (203.21 KiB) Viewed 8400 times
Final acid etch 8.JPG (219.36 KiB) Viewed 8400 times
Offside wheel arch 021.JPG (141.64 KiB) Viewed 8400 times
Offside wheel arch 024.JPG (154.58 KiB) Viewed 8400 times
Offside wheel arch 025.JPG (185.14 KiB) Viewed 8400 times
Offside wheel arch 028.JPG (160.09 KiB) Viewed 8400 times
Offside wheel arch 029.JPG (169.75 KiB) Viewed 8400 times
Offside wheel arch 031.JPG (203.02 KiB) Viewed 8400 times
2014-06-13 11.46.16.jpg (222.31 KiB) Viewed 8399 times
2014-06-13 19.55.01.jpg (193.12 KiB) Viewed 8399 times
2014-06-13 19.55.39.jpg (232.87 KiB) Viewed 8399 times
2017-01-09 14.08.29.jpg (510.9 KiB) Viewed 8399 times
Rear Bush Before.jpg (81.06 KiB) Viewed 8398 times
WIP:
Suspension bolts re-plated using a "Gateros" kit. These were the first few I did, not perfect, but I got better at the process with the later bolts.
2015-01-09 15.29.37.jpg (208.49 KiB) Viewed 8397 times
2015-01-09 15.31.27.jpg (156.73 KiB) Viewed 8397 times
The rear brake stone guards were in a bit of a state, with missing bits and holes. I'm not too proud of the bodge I have made to make them at least functional, but at least they are not easily visible and will do the job.
Before:
2017-04-07 16.57.45.jpg (629.59 KiB) Viewed 4127 times
Aluminium plate cut to size:
2017-08-22 17.15.23.jpg (486.03 KiB) Viewed 4127 times
Replacement parts made. Ali shield pop-rivetted on, stainless steel strip curved around edge, POR 15 and sealant applied:
2020-05-18 19.20.19-1.jpg (168.84 KiB) Viewed 4127 times
Mounted back on the axle:
2019-04-19 13.50.10.jpg (242.84 KiB) Viewed 4127 times
New brake lines installed:
2019-04-20 15.11.35.jpg (289.93 KiB) Viewed 4127 times
